4x4 control switch l.e.d.'s
Old Jul 9, 2012 | 08:24 AM
cali bear 87's Avatar
cali bear 87 is on a distinguished road
Default 4x4 control switch l.e.d.'s
Does any one know what l.e.d.'s fit in the 4x4 control switch I only need the size for the indicator light I already changed the main one, its a 00 blazer
Old Jul 9, 2012 | 08:40 AM
rexmburns's Avatar
Super Moderator
Check thogerts page I think he has everything listed if not I'm sure he knows and I know he's willing to help.
Old Jul 9, 2012 | 11:02 AM
Thogert's Avatar
I'm not sure if you can just replace them in the 98+ blazers. I think they are soldered onto the control board.
But if you can remove them by twisting a base off then you need a PC74 bulb.
Old Jul 9, 2012 | 11:19 AM
rexmburns's Avatar
Super Moderator
See I told you he would know lol!!
Old Jul 10, 2012 | 09:38 AM
Yes they are solderd there are 4 I changed one it lights up the letters the other 3 are the indicators when you switch it to 2hi 4hi n so I just want to know which number are they so I could buy them
Old Jul 10, 2012 | 11:19 AM
Thogert's Avatar
It should be a PC74.
Old Jul 10, 2012 | 02:50 PM
Ok thanks
Old Aug 21, 2012 | 03:19 PM
onder's Avatar
onder is on a distinguished road
how did you change the one that lights up the letters?
Old Aug 22, 2012 | 01:23 PM
Pull out your switch box and open it the there is 4 lights soldered one is bigger than the 3, I forgot the size bulb it uses but they all go soldered remember so do it only if you are comfortable, the smaller lights are for the indicator showing if your t case is in 4hi 4lo or 2hi
Old Dec 11, 2012 | 10:04 PM
420Blazin4X4's Avatar
420Blazin4X4 is on a distinguished road
I bought leds from superbrightleds.com for the bigger 4x4 light that works letters I used a component 5 mm led and the hi and lo leds I used 3mm all have to be soldered and dont forget to wire leds to a resistor also..I learned after wasting several led`s..
The bulbs in the 98+ Blazers for the 4x4 switch and rear wiper switch are all soldered in..
RedBlazer 96
32
Jan 29, 2013 01:30 PM
madmack4
May 24, 2012 12:59 PM
cide
Nov 8, 2010 08:17 PM
waviaerith
May 22, 2010 10:02 PM
kota04sxt
Dec 10, 2009 09:34 PM
