91 S10 Blazer 4wd Speedometer
Old Aug 7, 2011 | 11:52 AM
dholm's Avatar
dholm is on a distinguished road
Default 91 S10 Blazer 4wd Speedometer
Hello everyone, I have a didital dash the speed started jumping all over, sometimes only registering 0. now mostly 0. Where to start, would 1 of the sensors cause this or could it be the dash assembly? Thankk you for any help.
Old Aug 7, 2011 | 01:08 PM
It is very possible that the VSS in the output housing of the transfer case is either dirty or bad. I have posted specs on the output typically found on the 2nd gens, but I'm not sure what the older speed sensors output. New ones should be >250mV-AC when you spin the driveshaft. The frequency is what, in your case, the DRAC (digital ration adapter controller) uses to then send a signal out to the dash.
Old Aug 25, 2011 | 06:16 PM
dholm's Avatar
Sorry to respond so sloww on the results. I was the VSS, had to remove the skid plate to get to it, it is hard to spot with the plate on! Thanks!
Tvojtko
20
May 4, 2013 06:51 PM
jamie640
Jun 15, 2011 06:13 PM
wolv2401
Apr 26, 2010 06:23 AM
Dafted
Jul 2, 2008 11:48 AM
error_401
Mar 17, 2008 06:39 PM
