92 s10 4.3 liter, blazer power window problem
Old Jan 2, 2012 | 09:46 PM
Chasen D's Avatar
Chasen D is on a distinguished road
Default 92 s10 4.3 liter, blazer power window problem
Hi, my 92 s10 blazer's power windows have stopped working. I replaced the circuit breaker and still no go. None of the four power windows work, and all were working few weeks ago. Neither the master module, or individual switches work. I've looked through the manual and searched online for any other causes, but have found none. Is there another fuse/breaker inline somewhere? What else could it be? Any ideas would be helpful
Old Jan 2, 2012 | 10:09 PM
xgiovannix12's Avatar
sounds like the driver side front door switch
I think thats the main switch for the other 3 windows
you might wanna check if you have power going to that switch . There should be 1 wire with direct power
Old Jan 2, 2012 | 10:46 PM
richphotos's Avatar
Probably a shot in the dark, but have you tried the passenger window, and the 2 rear windows with the switch located on the doors for those windows, or are you just trying with the master switch panel located on the drivers door?
Old Jan 5, 2012 | 02:49 PM
Chasen D's Avatar
Hi, thanks for the info, I swapped out the master switch on driver side door. Still no go. So just to recap, new breaker, new master switch, still no power on any of the windows. Windows all stopped working at same time. Any other ideas?
Old Jan 5, 2012 | 02:51 PM
Chasen D's Avatar
and yes, I tried each window switch individually along with the master switch.
Old Jan 5, 2012 | 03:05 PM
do you have power to the master switch ?
Old Jan 21, 2012 | 09:51 AM
Chasen D's Avatar
apologize, been out of town, going to check on the power to master switch next. Thanks
Phandango
Nov 22, 2019 07:22 AM
green dot
Nitrous, Super Chargers, & Turbos
Nov 16, 2012 02:34 PM
mxpxpunkrock1987
Jul 1, 2011 01:51 AM
willmac1211
Feb 14, 2010 07:19 PM
jap06
Oct 23, 2007 10:20 PM
