6.0 Liter Encine Swap into a 90 k5 blazer
Old Feb 9, 2010 | 06:00 PM
willmac1211's Avatar
willmac1211 is on a distinguished road
Default 6.0 Liter Encine Swap into a 90 k5 blazer
anybody done this swap?? thinking about doing it any advice or info appreciated
Old Feb 9, 2010 | 06:01 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i'd do a 7.3L, some of the old k5s had a 6.2L diesel.
Old Feb 9, 2010 | 06:05 PM
It shouldn't be too difficult. Basically, tear out the ECU that you have and replace it either with a stand alone unit or try to integrate in a stock PCM and engine harness. All depends on what you can get with the motor.
You will have to upgrade the fuel system as well because the fuel pressure required for a TBI motor is a lot lower than what is required for a MPFI engine. Those LS based engines can make some wicked power though!
Old Feb 9, 2010 | 06:06 PM
Banned
do a build thread if you end up doing it.
Old Feb 9, 2010 | 06:37 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
6.0 is defiantly a nasty engine but going to obii is going to be a plan.
Old Feb 9, 2010 | 06:38 PM
Banned
pain?
Old Feb 9, 2010 | 06:44 PM
Could be a pain or could just be $$$. There are quite a few stand alone ECUs available for the LS engines that are quite easy to implement.
Old Feb 9, 2010 | 07:20 PM
zedartwo's Avatar
That would be sweet. Nice power!
Old Feb 9, 2010 | 10:01 PM
old skool luvr's Avatar
why the hell would you put in a Ford diesel?!?
if anything, you upgrade to a 5.9 (or a 6.7 if you have really deep pockets). those Cummins are pretty much a bottomless pit of power.
Old Feb 9, 2010 | 10:10 PM
Banned
because of ford power BABY!!!!!!!!
