95 blazer s10 turn signal wont work with headlights on
Hi guys,
Im Ray and I'm brand new here, just registered. I have a good one. So I just bought a Blazer and the left turn signal has some issues
It wont work while the headlights are on.
It stays on, just the left blinker lit and blinks maybe once every 4 or 5 seconds.
The right blinker works fine.
The bumper on the left side, right on the left blinker was dented pretty bad. enough to where ill need a new blinker housing.
Im pretty sure its not going to be as simple as replacing a bulb or fuse, since the headlights are what influences it, so somehow a wiring issue with the headlights are to blame.
Could it be a connection problem? Worn or disconnected wires somewhere in the housing or a wire harness? bad ground?
idk im confused. let me know if you have any ideas
thanks
ray
thanks
ray
problem fixed. changed the blinker/park light bulb and it works fine. electrical issues are weird. simple fix. now i have to fix the back hatch. it wont open with the key or with the back hatch button.
on a side note. every inside light on the vehicle is broken except one. out of the 4 rotator bulbs on the top panel only 1 works when i press the button. one is missing an entire bulb and insert cover and the other 2 have covers. the dome light also doesnt work. i took off the cover and the bulb looked fine. might try replacing that though. how hard is it to get all of the lights working. the one in the top back doesnt work either. also, the electric mirrors dont work and i think its a bad motor. does that sound like a hard fix?
