96 Code 43
Old Feb 18, 2011 | 04:29 PM
J_Blazer's Avatar
J_Blazer is on a distinguished road
Question 96 Code 43
Great site!
I've gone through here searching for like problems with the Code 43 -ESC issue. Gotta few questions:
I need a few things defined.
What is SES light?
What is ICM?
What is ECU?
How are the Codes "reset"?
I have a 96 Blazer and got the Code 43 warning. From what I am picking up here on this site, I am going to run the same equesnce of tests to solve this problem. I am not sure what the above mean...
Thanks
Old Feb 18, 2011 | 05:27 PM
dshuld's Avatar
dshuld is on a distinguished road
What is SES light? service engine soon
What is ICM? ignition control module
What is ECU? engine control unit
How are the Codes "reset"? I reset mine with a scanner but, disconnecting the battery works also. Before I bought the scanner I disconnected the battery for 15 minutes and then after reconnecting let it idle for 15 minutes. I'm unsure if that is long enough for the ecm(engine control module) to relearn the idle on these but, I never had a problem with it in the past.
I bought the scanner because I was having some major issues going on and wanted live data while I was driving.
Old Feb 18, 2011 | 06:52 PM
43 is not a valid OBD2 code which would result from a check engine diagnosis. A valid code would start with a letter and be followed by 4 numbers as described at the beginning of the OBD2 code index thread linked to in my signature below.
Old Feb 18, 2011 | 09:18 PM
J_Blazer's Avatar
Question Code 43
I do not have a code reader. I used the paper-clip method in the A&B terminals. The result was 43 which is designated ESC: electronic spark control= ESC module not receiving knock sensor signal (per GM TBI Trouble Codes).
Fuel delivery system?
A code 43 can be caused by a faulty connection at the knock sensor?
short to ground?
check my cap and wires?
Where am I wrong here?
Have I been led astray?
94 2-door
Old Feb 19, 2011 | 07:04 AM
caditech's Avatar
caditech is on a distinguished road
Knock Sensor (KS) Circuit i would just check the wiring to the pcm first and if that turns out allright, put a knock sensor in it. (is it a 94 blazer?)
Old Feb 19, 2011 | 11:59 AM
Ok... Original description was 96. If it is a 94, then the info provided is correct for the code.
Old Feb 19, 2011 | 12:14 PM
rriddle3's Avatar
Knowing the model year of your vehicle - priceless.
Old Feb 22, 2011 | 03:00 PM
J_Blazer's Avatar
Thumbs up Thanks
Thanks for the info folks. I will run the suggested routines...as soon as I dig it out of the recent snow storm.
Yes it is a 94.....
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
