96 s10 blazer headlight removalmoval and replacement
2 Attachment(s)
Ok so i have attached a picture of the headlight assembly i have in my 96 blazer. I would like to replace them and upgrade the bulbs so they are brighter and i can see better but i cant seem to figure out how to get them out. I am also wondering if there are sealed beam lights inside the assembly. Im asking this because every time search for replacement healights it comes up with 4x6 sealed beam replacements but it doesnt look like thats what they are. any help would be much appreciated.
Looks like you have the composite headlights, open up your hood, and look behind the headlight, should be able to remove the bulb, and find out what kind it is, I am not exactly sure what bulb yours uses.
your hi-beam bulb is a 9005, low-beam is a 9006. They're real common
well heres the problem with it i cant seem to get to the back of the headlight because of the mounting bracket and on the front of the headlight there are 4 clips which seem to hold the front lense on
the only way i can see to get it out is to completely unsrew the adjusters
*added link for removal in next post*
i can try that and then prying the front lens off to get to the bulbs it seemed to be sealed pretty tight anything i should do when i put it back on or will it just seal back up
Originally Posted by evfeez25
(Post 564898)
Replace Headlight Bulbs On A 1996 Chevy Blazer, S10, GMC Jimmy, Sonoma
ok so if you are having trouble as i did check out this link it was very helpful shows you exactly what you have to do. Thanks if you tried to help but here's the correct way |
| All times are GMT -5. The time now is 07:24 PM. |
