97 Blazer - Voltage Drop (especially from stock accessories)
Old Nov 12, 2019 | 12:32 AM
Mbkelite's Avatar
Mbkelite is on a distinguished road
Default 97 Blazer - Voltage Drop (especially from stock accessories)
1997 Blazer with 250 Amp Alternator - 2 Gauge OFC Big 3 upgrade + Additional Ground for battery
I have currently been dealing with an issue I've been unable to solve.
First off, my dash voltage seems to be very inaccurate, showing 10-11V when meter test at 13-14v
I'm running approx 3200 watts of stereo equipment (measured at approx 60-100 amp pulls when at max) with a 250 amp alternator, However I am not convinced the alternator is working fully (brand new but possibly defective)
Music doesn't begin to drop voltage until it pulls a large amount of amps, 60-100 amps will drop my voltage to 13.4 or so (tested with fluke meter) , however I get pretty noticeable light dimming and dash light dims.
However, when using stock instruments such as AC, Windows, or even my brakes, I get a noticable drop more than my 60 amp pulls from stereo, This DOES occur without music running, only one instrument at a time dims my lights to nearly 50%.
I am curious if could be anything other than simply a bad ground.
Perhaps a specific fuse link or built in module that is common between these stock instruments.
Edit-- My voltage does seem to return to normal after 2-3 seconds , as though my alternator is simply slow to respond to increased loads.
kenneth883
Dec 3, 2011 10:11 PM
helo
Aug 10, 2010 09:12 AM
R2P
Aug 7, 2010 08:04 AM
ExplicitYourSelf
Nov 12, 2009 09:52 PM
ltown21
Dec 9, 2007 09:39 PM
