99 Blazer fuel pump test connector
Old Sep 8, 2014 | 09:04 AM
tjchevy59's Avatar
tjchevy59 is on a distinguished road
Default 99 Blazer fuel pump test connector
Hey guys,
I have a 99 Blazer with a no start condition. "0" PSI measured at the rail. No pump sound from the filler tube when the key is turned on. It will run briefly with starter fluid applied. SO, the logical conclusion would be a bad pump. I would like to check the 12V power to the fuel pump and I am looking for a way to accomplish this without having to drop the tank....at this point in time. I know the Passlock system could be involved here so I want to check the pump out first as the vehicle has been sitting for a while which further indicated a bad pump.
Found this basic wiring diag on the net and was wondering if there really is a "fuel pump test connector" under the hood where I could measure the primer pulse voltage for the 2 sec after the key is turned to on? If not, can I measure it at the "G" pin on the ALCL connector?
Thanks in advance for any assistance.
Attached Thumbnails 99 Blazer fuel pump test connector-wiringdiag_zps00b2c469.jpg
Old Sep 10, 2014 | 07:16 AM
tjchevy59's Avatar
Hello,Hello,Hello
Is there anybody out there?
Just nod if you can hear me.
Is there anyone at home?
Come on now
You know I'm feeling down
Well, can you ease my pain
And get me on the road again
I'll Relax
But I need some information first
Just the basic facts
Can you show me where to probe?
Old Sep 10, 2014 | 08:09 PM
chris015's Avatar
Not sure,but to test power etc. get a manual,find what wire supplies power,find it on the frame,nick it,and test. easy?
blazers eat pumps,balljoints,idler arms,and manifold gaskets. do it all with oem parts. good to go 500000000000000000000 miles.
Old Sep 11, 2014 | 04:42 PM
rexazz2's Avatar
the test lead on gm trucks is usually along the fire wall
If I remember right , drivers side
Usually about 8-10 inch long wire with a square black connector on it
Old Sep 12, 2014 | 07:53 PM
mvamobile's Avatar
mvamobile is on a distinguished road
On my 95 it is located on the drivers side quarter panel. There is a power block where the fusible links connect. Look between the power block and the firewall. There is a black wire there with a black square connector on the end.
Old Sep 15, 2014 | 06:15 PM
tjchevy59's Avatar
In case someone else is in need of this info. The terminal just to the left of the FP relay will light a test light in the key on position for 2 seconds (prime) indicating that voltage is probably being applied to the fuel pump in the key on position.
After verifying that, I went to the tank and measured the voltage across terminal B and C on the FP module connector (power and ground to the pump) Measured 12 volts there for around 2 seconds after turning the key to the on position so now I am convinced the pump is bad.
I will now drop the tank and test the pump before I buy a new one...if it won't run with 12 volts directly applied....it is dead for sure.
Attached Thumbnails 99 Blazer fuel pump test connector-dsc_0154-copy-1_zps4c050e4c.jpg   99 Blazer fuel pump test connector-2010-11-09_141011_fuel_pump_connector_zpsdc1755bf.gif
Old Mar 22, 2022 | 02:36 AM
larrymaysey's Avatar
larrymaysey is on a distinguished road
yo i can see you.yeah it hard somti
PayneSource
Dec 21, 2011 01:28 AM
terbates
Feb 2, 2011 11:03 PM
arrowsbydish
Dec 18, 2008 07:32 PM
Terry W
Apr 10, 2008 02:37 PM
jim45
Oct 25, 2007 08:19 PM
