99 blazer lighting issues
Old Sep 14, 2012 | 02:04 PM
dawn hill's Avatar
dawn hill is on a distinguished road
Thumbs up 99 blazer lighting issues
I have a 99 blazer and when i start the truck day or night my headlights and taillights come on even with light switch off. replaced relay still happens any ideas also tried the dome switch override for 2000 and up blazer to no avail
thanks in advance
gm forever
Old Sep 14, 2012 | 03:05 PM
warthogdriver's Avatar
that is normal
drl = daytime running lights
ahl = auto headlights
there is a way to disable them both...but depending on where you are it may be illegal to disable them.
it is easy to disable them...search drl and ahl disable.
the dome switch trick will only work on 2000 and up and it only works once...you would need to do it everytime you get in the truck.
Old Sep 29, 2012 | 01:54 PM
dawn hill's Avatar
no there is an issue because there is a switch normally if you go thru a tunnel the lights would switch from drl to ahl no longer switches lights are now on all the time.
BigBlueBlazer
Apr 30, 2014 08:21 PM
drumminsoul
Nov 3, 2011 07:18 PM
blazin8s
May 27, 2011 01:24 PM
Keycube
Apr 19, 2010 08:59 AM
Frostbitte
Apr 2, 2009 02:28 PM
