ABS and Brake light on? Here's a tip
Old May 7, 2016 | 09:45 PM
moosehauler05'blaz's Avatar
moosehauler05'blaz is on a distinguished road
Default ABS and Brake light on? Here's a tip
Hello folks ! Well last week we had a rain storm and my ABS and Brake light came on ..and i changed the whole brake system last winter (upgraded)
What i failed to do was check the ground wires for rust and dirt
The ground wire (2000 - 2005) is on the rad support wall drivers side half way down were the Air filter box is
I removed the box and removed the bolts cut the old wire clamp washers off
and bought new stainless self tapping bolts and new wire clamp washers Sanded down the hole around the bolt with 80 grit sandpaper and rubbed dielectrial grease on the hole and washer and bolt
No Lights on now
Should be good for another 11 years
Hope it helps
steve72
Sep 1, 2014 11:41 PM
Diablo1982
Aug 18, 2011 11:08 AM
beastbandit92
Aug 13, 2010 08:24 PM
damageinc98
Jul 12, 2010 10:47 PM
megtom2
Nov 24, 2007 10:36 AM
