My 98 blazer airbag light comes on at any given time. How can I fix this?
If my airbag light comes on periodically, would it prevent my cruise control from working properly? Anybody knows?
Vahomboy
09-06-2016 06:22 AM
My air bag light comes on randomly and so far I haven't noticed any issues with cc.
Rusty Nuts
09-06-2016 03:06 PM
Cruise control and airbags are separate systems. A problem with one won't affect the other. The first step is to scan the codes. The scanner must be SIR (supplemental inflatable restraint) capable.
rockp2
09-06-2016 05:53 PM
The wires for your multifunction switch (turn signal) and CC are in the same thick bundle of wires running down your steering column to body electrical connector C211. The connector is at about the 10 or 11 o'clock from your brake pedal...pretty close to your P-brake ratchet mounted on the firewall. It's a big 48 pin connector about an inch or so wide and a couple inches long. If you get your head up under your knee bolster you can see it pretty clearly. The airbag wire is big and yellow. I'd wonder whether or not you have some intermittent short between the CC wires and Airbag wires somewhere between the multifunction switch and connector C211.
iceblue068
09-06-2016 07:47 PM
So where or who can detect this short and how to begin this process?
rockp2
09-07-2016 03:27 PM
Originally Posted by iceblue068
(Post 668556)
I would take off the knee bolster and the steering column cover and take a look at the wires to see if you see any breaks. After thinking about it further, I'm more inclined to agree with rusty nuts in that you might be dealing with two separate issues. Though the wires are bundled together at the steering column, they are secured pretty well. So unless the CC wire overheated and melted both the casings on both wires, you probably don't have a short. However, that being said, the possibility is still there and since the wires are also near where the steering column tilts...anything could happen. But I'm leaning away from a short.
To do a correct troubleshooting I'd recommend you go to either alldatadiy.com or eautorepair.net and sign up for a subscription to the Technical Service Manual for your truck. It's under $20 and they are the manuals the dealers use. There you can find step by step troubleshooting procedures (there is a ton of steps) as well as images and wiring diagrams.
