Alternator Upgrade Question
Old Dec 17, 2012 | 04:04 PM
tibby's Avatar
Default Alternator Upgrade Question
Okay. Have a question about an alternator. I called up a shop and the guy has a 02 Chevy Silverado Alternator off of a 5.3. He didn't know the model number on there. But I just found an 05-07 Silverado Escalade Alternator on eBay for cheap. Would it fit?
This link
Old Dec 17, 2012 | 04:12 PM
Twip's Avatar
i dont know for sure. but you if the shop is close by, just cruise over there and size it up. some quick measurements and sizing should tell you all that you need. another thing i dont know is weather the amp difference will be a factor. might want to try and check that too, or do some more research.
Old Dec 17, 2012 | 04:31 PM
tibby's Avatar
Default .
Well. I know this post has been on here for awhile. But no one has ever mentioned the alt I referenced in the original post. Maybe this one would fit instead.
Old Dec 18, 2012 | 04:34 AM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
call the auto parts store they'll be able to tell you with cross referencing worst case scenario go to the auto parts store look at them both at the counter....
Old Dec 18, 2012 | 09:30 AM
neo71665's Avatar
You want an ad244 off a fullsize. It will have the reg built in and the electrical plug will have 4 prongs. Some of the newer trucks have the ecm control the reg and the electrical plug will only have 2 prongs.
The ad244 is bigger and requires a longer belt. It does bolt in. I ran one on my blazer 2.8 and 3.4 engines before my v8 swap and when its done it'll have one on it.
Old Jan 14, 2013 | 08:35 PM
gitch93's Avatar
gitch93 is on a distinguished road
ok not much threads about the alternator upgrade but i got a 2000 jimmy and my entire electrical system us upgraded from a optima red top to the big 3-4 gauge wire mod. what gm years and alternators will bolt on and give a high amp rating over the stock 100. i been trying to research rebuild kits but no luck. i run alot of offroad lights and a 9500 pd winch with stereo and hids any help would be thankful
Old Jan 14, 2013 | 08:51 PM
richphotos's Avatar
I do not mean to be rude, But look at literally the post right above yours, Tells you exactly what you need
julioAKAjunior
Apr 29, 2013 09:53 PM
kenneth883
Dec 3, 2011 10:11 PM
ComputerNerdBD
Aug 1, 2011 04:46 AM
timmi79
Jan 6, 2010 10:52 AM
ThisSideUp
Jul 18, 2005 04:51 PM
