Alternator vs Puddles?
Old Jan 13, 2014 | 09:29 PM
White Locust's Avatar
White Locust is on a distinguished road
Default Alternator vs Puddles?
I've had my 2000 Blazer 4X4 die twice in the past week just as I got it home. Driving home at regular speed, (thru bad slushy winter weather) pull into park and I notice the amps drop from 14 to 12,11,10 then slowly drain out to nothing. First time I jumped it and drove it the rest of the week without an issue. I hit a fairly big puddle both times so i wonder if that has anything to do with this problem. Someone had mentioned the relay IN the alternator is bad as well. Open to suggestions.
Old Feb 13, 2014 | 10:56 AM
The gauge on the dash is the system voltage. If it drops to nothing with the engine running and in short order and the engine doesn't stall, I would wonder if there isn't a problem with the ignition switch providing power to the cluster. Is the volt gauge the only one that shows signs of having a problem?
Old Feb 14, 2014 | 11:37 AM
I have replaced the battery and since have had to get a boost. Sometimes when I turn it over the gauge sticks at 9 till I rev up a bit then it kicks up to 14. the volt gauge is the only gauge that has a problem. until the amps drop to 0 then everything dies...radio, speedometer, tachometer
bigdaddykane93
Jan 14, 2010 06:56 AM
daddyduck
Sep 30, 2009 09:44 AM
blazer1
Jul 25, 2005 05:04 PM
ThisSideUp
Jul 18, 2005 04:51 PM
shawnCRX
Jun 11, 2005 03:47 PM
