Another ABS question.
Old Feb 19, 2011 | 09:43 PM
Greg's Avatar
Greg is on a distinguished road
Question Another ABS question.
Hey guys & gals,thought Is get your feed back on this before I did anything.So here goes.I have an 01 Blazer and I've noticed my ABS light flash a few times.Now I've noticed when I take a curve and the weight shifts to the drivers side the light comes on and while parked and running if I turn all the way towards the drivers side the light will come on then go off again.I was thinking wheel bearing assembly.....what do you think?
Old Feb 19, 2011 | 10:05 PM
Schrade's Avatar
Schrade is on a distinguished road
Why were you thinking 'wheel bearing assembly'? Are you still thinking that?
Old Feb 19, 2011 | 11:09 PM
Greg's Avatar
Well,I kinda figured if the bearings are going bad it would put pressure on the ABS ring.My light started flashing in my Silver,then the wheel started grinding.
Old Feb 20, 2011 | 12:24 AM
Schrade's Avatar
Hmm... Interesting. Do ABS sensors measure hub pressure on the bearing?
If they do, or even if they don't, I'd probably get a new bearing installed, then attack ABS diagnostics afterward... Seized bearings WILL ignite brake fluid, just as fast as pad rivets on the bare rotor. Seen it happen...
Old Feb 20, 2011 | 06:03 AM
Moores12345's Avatar
Moores12345 is on a distinguished road
Don't think bearings will bring up the ABS light. Never did when I had to replace the hub on the driver side anyways. Take the fuse out and see how it works, could be a sensor gone bad also.
Old Feb 20, 2011 | 05:45 PM
Greg's Avatar
Thanks for your help guys.
Trb
Feb 3, 2015 09:41 PM
iamchevyman5
Nov 17, 2010 06:30 PM
chrishorton74
Jun 2, 2010 09:03 PM
coplinb
Sep 30, 2007 06:37 PM
metalhead
Aug 12, 2007 09:16 PM
