any 1 know the wattage for the dome lights under the dash ?
Old Oct 16, 2011 | 09:22 PM
xgiovannix12's Avatar
Default any 1 know the wattage for the dome lights under the dash ?
i have regular bulbs in there and they get 2 hot i really think im overloading the system
I think there 27 watt bulbs there the ones you can use for your reverse lights
also is there a set of white leds for them ?
Old Oct 17, 2011 | 12:26 AM
Thogert's Avatar
Superbrightleds.com has just about every bulb for cars, and most in lots of colors. They also have a vehicle bulb finder that can tell you which ones you need. On mine they are the t10's, but it may be different on the first gens.
Old Oct 17, 2011 | 12:48 AM
thanks thogert but i think imma put reg bulbs for now
I needa see what kind go there cause the ones i have they heat up to much
Im afraid im over loading the system
Old Oct 17, 2011 | 12:57 AM
Thogert's Avatar
Is it wedge based?
Edit: I mentioned that they may be T10's. The corner lights on your dads s10 have T10's. you could see if those fit than those are the ones you need.
Old Oct 17, 2011 | 05:46 PM
No they are like the bulbs you put in your reverse sockets just the ones i put are 27 watts
I think they are the ones causing my radio horn dome light fuse to get hot
Old Oct 17, 2011 | 08:39 PM
Mike98Blazer's Avatar
replace them with lower wattage bulbs?
I'd say 27 watts is definately too much for courtesy lighting, considering most headlights are only 55 watts lol
Old Oct 17, 2011 | 08:55 PM
yea it was so nice to have them they were so bright
Old Oct 17, 2011 | 09:04 PM
pettyfog's Avatar
I GUESS!
Automotive Bulb Visual Finder
is a dome light
is plenty for a footwell light
Old Oct 17, 2011 | 09:18 PM
there arent t10s or t15s they look like 1157s
Old Oct 18, 2011 | 01:56 AM
Magmotor's Avatar
Magmotor is on a distinguished road
Here is a complete list of every bulb in a '93 and replacement needed:
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Here is the link to Auto Zone's "step/courtesy" light (12 watts) that matches what is in my service manual for this application:
Sylvania/Trunk / Cargo Light Bulb (1003LL) | AutoZone.com
hope this helps a little.......
