-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   any 1 know the wattage for the dome lights under the dash ? (https://blazerforum.com/forum/lighting-electrical-52/any-1-know-wattage-dome-lights-under-dash-64090/)
xgiovannix12 Oct 16, 2011 09:22 PM
i have regular bulbs in there and they get 2 hot i really think im overloading the system
I think there 27 watt bulbs there the ones you can use for your reverse lights
also is there a set of white leds for them ?
Thogert Oct 17, 2011 12:26 AM
Superbrightleds.com has just about every bulb for cars, and most in lots of colors. They also have a vehicle bulb finder that can tell you which ones you need. On mine they are the t10's, but it may be different on the first gens.
xgiovannix12 Oct 17, 2011 12:48 AM
thanks thogert but i think imma put reg bulbs for now
I needa see what kind go there cause the ones i have they heat up to much
Im afraid im over loading the system
Thogert Oct 17, 2011 12:57 AM
Is it wedge based?
Edit: I mentioned that they may be T10's. The corner lights on your dads s10 have T10's. you could see if those fit than those are the ones you need.
xgiovannix12 Oct 17, 2011 05:46 PM
No they are like the bulbs you put in your reverse sockets just the ones i put are 27 watts
I think they are the ones causing my radio horn dome light fuse to get hot
Mike98Blazer Oct 17, 2011 08:39 PM
replace them with lower wattage bulbs?
I'd say 27 watts is definately too much for courtesy lighting, considering most headlights are only 55 watts lol
xgiovannix12 Oct 17, 2011 08:55 PM
yea :icon_no: it was so nice to have them they were so bright
pettyfog Oct 17, 2011 09:04 PM
I GUESS!
Automotive Bulb Visual Finder
is a dome light
is plenty for a footwell light
xgiovannix12 Oct 17, 2011 09:18 PM
there arent t10s or t15s they look like 1157s
Magmotor Oct 18, 2011 01:56 AM
Here is a complete list of every bulb in a '93 and replacement needed:
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Here is the link to Auto Zone's "step/courtesy" light (12 watts) that matches what is in my service manual for this application:
Sylvania/Trunk / Cargo Light Bulb (1003LL) | AutoZone.com
hope this helps a little.......
