arghh! turn signal issues....
I really think the issue is the socket... You can always swap the relays from your dads truck to yours . LOl
Edit: makes me wonder when the blinker is solid (on the cluster) do you hear the click sound? does the passenger side operate normally?
I dont think its the relay, either a problem with the bulb or the socket. Check and make sure there is not a piece of metal inside of the socket from the old bulb that is connecting causing it to short out.
checking for crap in the socket was the first thing i did.
No luck at all gio. Jason i replaced everything (every bulb from the rear) and tested them all while the housings were removed. All my outside bulbs work. Thats why im so confused on why its still blinking fast.
