blazen_red_4x4 |
12-08-2017 11:44 AM |
My last setup I ran behind the molding along the side of the windshield and the door weatherstripping. I set it up without cutting or drilling any holes in the roof. Hid the wires pretty well, but they had a tendency to work they're way out every once in a while...
I ended up removing that light bar later on so it worked out great. The setup I'm planning now though will require drilling and sealing the roof... There will be multiple light bars on the roof, facing forward, backward, left, and right, all mounting to a roof rack. There will be a 4 gauge power and 4 gauge ground running up the passenger side just behind the rear seat area and I'll pass it up through the roof, have an auxiliary fuse and relay box mounting in a box in the roof rack, a multi-conductor wire running from the control box down through the roof as well to switches in the cab to control all the lights individually from in the cab. But that'll certainly be more work than tucking some wires behind some weatherstripping lol
