Better alternator and big 3?
Old Aug 13, 2013 | 02:48 PM
bear159's Avatar
bear159 is on a distinguished road
Default Better alternator and big 3?
Well right now I have 8 extra lights on my jimmy, and a sub and amp.
Four lights are 130 watt each and the other four are 55 watt lights, amp is 300 watts.
Anyways Today my friend wanted to see all of my lights on at the same time. When I put them all on I noticed that instead of the volts hovering a bit below 14 it wen't to the red just about where it says 9 volts...
I knew it would go down but not that much, plus I never have to run everything at once, so I was wondering do you think the big 3 with 4 awg wire will help or should I get a alternator out of a 1500. I think its the AD244 with 145A from the 1500?
Old Aug 13, 2013 | 03:17 PM
rexmburns's Avatar
Super Moderator
Start with the Big 3 and see what that does for you and if that's not enough upgrade the alt. You will want the big 3 done anyway if you upgrade the alt so may as well start there I have a DR44G alt with 0awg Big 3 in my truck and with efans on high, all my lights on, radio on, and in gear at an idle I have zero volt drop
Old Aug 13, 2013 | 04:26 PM
bear159's Avatar
Alright, thanks for the help rex!
I will get some wire soon and see how much it drops after that.
Old Oct 30, 2013 | 01:39 PM
Blade_24k's Avatar
Blade_24k is on a distinguished road
probly a stuipid question but where do i get 0awg wire? would my local autoparts store have it? or would i have to find some specialty shop like an audio store?
Old Oct 30, 2013 | 02:10 PM
dirt101's Avatar
dirt101 is on a distinguished road
I recommend ordering it off ebay or something. Sky high car audio has some good inexpensive 0ga wire as well as solid copper lugs to terminate the wire.
Old Oct 30, 2013 | 03:39 PM
chris015's Avatar
http://www.knukonceptz.com/productMaster.cfm?category=Power%20Wire
this place is the ****. seriously. High quality wire,and cheap.
Old Oct 31, 2013 | 01:20 AM
Thogert's Avatar
Regular auto stores do not carry something like that. Wayy too specialized for them. Not to mention most of it runs over $10 a foot.
BLAZER97LS
Nov 17, 2012 03:15 PM
sam.myers1985
Mar 13, 2012 11:43 PM
chris015
Engine & Internal
Jul 25, 2011 09:13 PM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
