-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Big 3 Upgrade: I've searched, but... (https://blazerforum.com/forum/lighting-electrical-52/big-3-upgrade-ive-searched-but-83167/)
Diaita Dec 6, 2013 06:09 PM
Ok, I searched a little bit. I'm looking for wire lengths and eye sizes, if anybody happened to measure them when doing the upgrade. :icon_flowers:
El_Beautor Dec 7, 2013 08:56 AM
Sorry, can't help you there man. I just pulled whatever fit out of my scrap box. I used to be an automotive electronics installer so I have a big box of spare wire lengths and a whole bin full of ends. If you happened to be coming through Edmonton I'd let you help yourself to whatever I have.
Diaita Dec 7, 2013 11:15 AM
I have a heap of welding cable and the crimp on ends at work, but the crimper we use is about 250 lbs, and bolted to the bench. Kinda tricky to get home. No big deal, if someone had them, I could have just made them up and bolted it together this weekend. I'll post up what I use after I git'r done.
KerbyG Dec 17, 2013 11:07 AM
When I worded 6' from a supplier, they sent me 7' by accident (it was longer than I am tall, and I'm 6'5" haha) no complaints though :-P
Long story short, I cut it to 2, 2' lengths, and 1, 3' length, and had plenty of slack to run everything without binding the wires during engine flex. I couldn't help you with the eyelets however, since i used some copper plumbing pipe, flattened one end, drilled the eye, and soldered them on. Held up great now for almost 2 years.
Diaita Dec 17, 2013 01:45 PM
Thanks Kerby!
KerbyG Dec 17, 2013 04:42 PM
No problem man!
Diaita Dec 18, 2013 04:09 PM
Found some other info that may be helpful:
Factory Positive
Factory Negative
gpgab97 Dec 18, 2013 04:21 PM
I love the idea of using plumbing copper and solder to make lugs from! Homebrew rocks!!
KerbyG Dec 18, 2013 04:39 PM
Hell yeah! Hahah. If I can make it instead of buy it, and its the exact same thing, why not right?
And those are interesting Diaita, but that's actually the same gauge wire mine had on it from factory. I beefed those babies up to 0-1awg
Diaita Dec 18, 2013 05:59 PM
It tells us what the terminal sizes are, and wire lengths(these are for a '96). I think I'm just going to make complete cable assemblies to swap in, with 1/0 welding cable in the high current sections.
