-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Big 3 Upgrade: I've searched, but... (https://blazerforum.com/forum/lighting-electrical-52/big-3-upgrade-ive-searched-but-83167/)
newguy Dec 27, 2013 05:13 AM
I believe you can replace it, but I and a lot of other people put it on in addition to the stock wire
KerbyG Dec 27, 2013 09:48 AM
Exactamundo! You can do either, I took mine out, just to save on clutter.
Diaita Dec 27, 2013 04:05 PM
Also, 1/0 is a lot bigger wire than needed, I have access to it cheap is the only reason I'm using it. If you keep the existing wiring, you don't need to run as large of wire as it will have 2 paths to follow.
newguy Dec 27, 2013 04:50 PM
I have 2/0 on mine and my charging system shows 14.3 volts at idle
Diaita Dec 27, 2013 05:32 PM
My Blazer shows over 14v at idle with everything on now, and it still has stock wiring. This is the second step toward a winch. First was the 78 series dual post AGM, next will be the 145A alternator, then the winch.
KerbyG Dec 27, 2013 05:47 PM
I'm using the ad244 off a Yukon with 2/0 wire without the factory wiring with the same size battery as stock, but its a top post, and I'm catching 14.7 at the battery with everything on
Badco Dec 27, 2013 06:13 PM
I'm running 14.7 (Might even be a little over 15) with a new alternator, stock wiring also. Def. interested in the lengths and eyes. I'm really wanting to do this soon.
newguy Dec 27, 2013 06:40 PM
My readings are with a volt meter at the battery, not the way off gauge on the dash
KerbyG Dec 28, 2013 03:40 AM
Yup, never trust that damn gauge, always always always check with a voltmeter
scottl1346 Dec 28, 2013 05:07 PM
big 3 made no difference lights still dim as they did be4 with stock wiring with everything on gonna look into a bigger alternator anyone have any suggestions?
