Blazer wont start/zero sound
Old Jul 9, 2012 | 08:54 PM
jwalker1992's Avatar
jwalker1992 is on a distinguished road
hummm well i know its not your starter or anything that has to do with your engine running it could be your switch is bad maybe or like i said a ignition fuse/relay thats your cheepest bet to try out first
Old Jul 9, 2012 | 09:23 PM
EdgarCervantes's Avatar
EdgarCervantes is on a distinguished road
how do i find my ignition fuse? and is there a way i can check if its my switch?
Old Jul 9, 2012 | 09:54 PM
well when you open the driver door look about bleey button high on your dash its hidden when you close the door there is a panal that you can take off it has all your fuses just check the ignition fuse if its burnt in the middle replace if you dont see a problem under the hood there should be a larger ignition relay im pretty sure its squear and black or gray and it should say have a ign on it or say ignition pull it out and take another one out of your buddys car or wife and test it to see if theres works if it starts up when you put in the relay you took out your buddy/wires car then yours is bad and you need a new one
Old Jul 9, 2012 | 11:09 PM
okay well i bought a new relay and its not that... :/
Old Jul 9, 2012 | 11:13 PM
well im not 100% sure unless its your switch and i dont think there is anyway to test it
Old Jul 9, 2012 | 11:33 PM
dam well alright.. really appreciate the help anyway. ill try to figure out more tommorow.
bobby01
Oct 30, 2014 07:36 PM
davtak
Oct 5, 2007 05:57 PM
