Brake indicator light
Old May 25, 2016 | 09:00 PM
ktshoema's Avatar
ktshoema is on a distinguished road
Exclamation Brake indicator light
95 blazer, w vin, with VCP. It is the bad year with the OBD1 system with an OBD2 plug.
I cant get my ABS or Brake indicator to go off. The ABS light as been on for years and I think I know what is wrong. The Brake indicator is another story. It just recently came on after I took the dash apart to change out the radio.
I have studied every wire diagram out there for a 94, 95, and 96 blazer. I keep finding "Diode Module" on the wire diagrams in line with the brake light indicator. I have take the dash apart 3 times looking for this module and Cant find it. Where is it??
Today, I checked napa and found this...
https://www.napaonline.com/napa/en/p...300_0341031982
I still can not find it in the blazer.
HELP! I need the light to go away to pass inspection. I pulled the bulb but it failed because it did not light up when he tested the indicator lights.
HELP!
Old May 26, 2016 | 11:10 PM
odat's Avatar
Just a thot and maybe not a good one but check your emergency brake for a switch that may have moved or disconnected while you were inside of dash or be bad and malfunctioning
dolphin1
Nov 8, 2009 07:24 PM
kthdwn
Nov 7, 2009 11:36 PM
PiTRiFF
Feb 13, 2009 04:31 PM
Daninehnj
Feb 22, 2007 02:26 AM
qbee1776
Apr 19, 2006 06:16 PM
