brake light wire melted 96 blazer
Old Dec 13, 2011 | 05:55 PM
zackmac7's Avatar
zackmac7 is on a distinguished road
Default brake light wire melted 96 blazer
i have a 96 blazer that keeps blowing fuses when i hit the brakes i did some serching and found a that the white wire going to the brake pedal switch is melted i was woundering what this wire goes to
Old Dec 13, 2011 | 10:30 PM
Rottidog's Avatar
My guess would be something that is grounded & it shouldn't be. Trace the wire, see where it's getting pinched or grounded out & replace it. It could have a bad connection at the other end causing the issues too. Brake lights work on a reverse switch or whatever it's called (open circuit - no brake pressure, closed circuit brakes on) meaning when you push the peddle it allows + power to light your brakes. You may have an issue with the brake light switch or along the wires to the lights. Ugly situation to trace for sure but it's the best place (& most promising) to start.
A Haynes manual has diagrams, step by step (for the most part anyway) procedures for a complete tear down & rebuild. Good $25 investment!
Nate Chesebro
Sep 27, 2012 09:05 PM
dano440
May 11, 2012 06:57 PM
jt77
Feb 5, 2011 05:31 PM
Benedict1337
Feb 5, 2010 02:15 PM
blazeitupdrgonzo
Dec 14, 2009 01:01 PM
