Brake lights don't work
Old Sep 1, 2014 | 06:44 PM
Deletedalien's Avatar
Deletedalien is on a distinguished road
Default Brake lights don't work
I searched and couldn't find anything here (maybe its here but couldn't find it)
so i have a 96 4 door Blazer with a 4.3 vortec (if that matters)
and only the third brake light works.
i checked the bulbs and they are all fine, so i know it's something else.
the left/right blinkers work the hazards wok. so.. what gives?
do you think it's the brake switch on the pedal? if so ... where is it??
Thanks in advance.
Old Sep 2, 2014 | 12:09 PM
Maggz's Avatar
Maggz is on a distinguished road
if the third light works, then it is not your brake light switch. Have you checked the connection in the rear wire harness to make sure they are not corroded or broken? The brake light switch is actually at the top of the pedal, it should be a 2 inch by 3 inch white plastic box which mounts thru a spring clip where the rod for the power booster and brake pedal linkage connect. I would be leaning towards something in the rear wire harness tho, especially if the third center brake light is working and not the actual rear markers.
Old Sep 14, 2014 | 11:11 AM
Sadchevy's Avatar
Sadchevy is on a distinguished road
The problem is not in the wiring, it's the hazard button on the steering column. The button will pull straight out. Clean it or get a new one from the dealer. To test it, wiggle it around while standing on the brakes, lights might come on if you hit the right spot.
project85
Jan 15, 2015 03:23 PM
gagthegoose
Jun 28, 2014 07:45 AM
ckroll98
Jun 27, 2013 04:41 PM
96jimmyslt4x4
May 29, 2011 03:55 PM
Shamrock3
May 30, 2007 01:58 PM
