A/C Control Module?
Old Dec 11, 2021 | 12:28 PM
aloha's Avatar
aloha will become famous soon enough
I ordered another control module on eBay that has a good return policy. See if that does the trick. JM
Old Dec 11, 2021 | 12:30 PM
aloha's Avatar
I will look for a wiring schematic of the female plug the controller attaches to and check to see if is getting power.
Old Dec 11, 2021 | 12:43 PM
GeorgeLG's Avatar
Here you go:
George
Old Dec 11, 2021 | 01:08 PM
aloha's Avatar
Very helpful. Thank you. JM
Old Dec 11, 2021 | 01:09 PM
GeorgeLG's Avatar
Let me know if you need anything else.
George
Old Dec 16, 2021 | 11:54 AM
aloha's Avatar
Power to the harness is fine. Should receive the used HVAC today.
Old Dec 16, 2021 | 12:43 PM
GeorgeLG's Avatar
Keep us posted.
George
Old Dec 18, 2021 | 08:54 PM
aloha's Avatar
Hello,
Plugged in the new (used) HVAC. Works like a charm. Problem solved. Thank you again for all your help!
-John
Old Dec 18, 2021 | 09:31 PM
GeorgeLG's Avatar
Hello,
-John
Glad your fixed up.
George
Old Dec 19, 2021 | 12:26 PM
aloha's Avatar
For anyone that may access this thread here is a link I found on removing the front bezel to access the HVAC. If you dash has been in the sun a lot over the years it can be quit brittle. I recommend putting some tape on the top portion in order to give it some addition integrity prior to pulling it away from the dash.
JM
