car wont start
This morning when I went to leave I went out and started my blazer like normal. Everything seemed fine and it started right up. it sat for about 15 seconds before I put it in drive after driving about 15 feet I lost ALL powe. so I turned the key to the offposition and when I did a clicking noise was coming from behind the passenger firewall. So I didn't think anything of it and went to turn the key and again absolutly nothing had power. I don't think is the battery because it is new. But I donthave a clue any ideas where to start trouble shoting would be nice.
Thanks
Austin
Thanks
Austin
The clicking noise coming from behind the passenger kick panel is your engine control module receiving a signal to start the vehicle. When it continuously clicks and doesn't turn over, its generally because it isn't getting enough, or any power at all from the starter. I would check the fuse block under the hood and make sure those are all good, (mainly the ecm fuse). But I can almost guarantee you that either the battery doesn't have a charge, or check to make sure the battery posts are on tight, sometimes with a new battery it takes a few snugs to get the threads to lock in properly (providing its side mount). Defiantely sounds like a connection problem between the battery and the ignition system.
Click is more likely the starter. If it sounds sorta like a single turn signal click, that's a relay. If it's more a 'clack', it's starter.
Turn lights on and watch them while trying to crank. If lights dim, a primary.. perhaps battery terminal... problem.
Check all battery cable connections, positive and ground, both ends
My lights do not come on. There is nothing on as far as I can tell.
Thanks for the help.
Austin
Austin
Drvr02RT
02-12-2010 06:31 AM
LSX7.0TT
11-21-2008 06:08 AM
broke33
05-01-2007 10:45 PM
JasonG
12-12-2005 02:19 PM
