Charging issue
Old Sep 18, 2019 | 09:29 PM
MotoDude's Avatar
MotoDude is on a distinguished road
Default Charging issue
So ive owned my 95 Blazer for about 2 months now and according to the gauge it has always charged a little on the low side. I got the alternator tested and was told it was bad. I just put in a new one tonight but im having the same issue. If im idling or driving around the needle stays about 12-12.5 volts. if i turn up my radio it drops down to about 10. I havent hooked up my multi meter to test the actual voltage, im just going off of the dash. Anyone else have this kind of issue. Any help appreciated.
Old Sep 25, 2019 | 06:46 PM
Ebbervonfloyd's Avatar
Ebbervonfloyd is on a distinguished road
Does it alway start? And you are right, you should check voltage at the battery with you multi meter. If it is low as you think and you have a new alternator i would think maybe a bad ground between body and engine. On the fire wall by ac box is a ground strap that goes down and connects to the back of the right bank of your head. You could take jumper leads and place on negative terminal of battery and the other to body of alternator. See if that makes any difference. Back of head bolt I think is 5/8 not a #10.
sags70
Aug 18, 2015 09:24 PM
mcdon26
Sep 28, 2012 10:58 PM
marksoftball
Feb 28, 2009 12:15 PM
guywm25
Aug 25, 2008 12:37 PM
zombiewoof
Feb 25, 2008 06:51 PM
