Clicking Noise
Old Jul 3, 2011 | 11:36 AM
arkman8208's Avatar
arkman8208 is on a distinguished road
Default Clicking Noise
Hello everyone, I recently purchased my first Chevrolet Blazer and thus far other than the owner I bought it from not taking care of it, it's been a really good little truck.
I have a 2000 Chevrolet Blazer LS 2 door 2 wheel drive. When driving the truck or just idleing with the transmission in park you can hear a clicking noise from the passenger front kick panel, (same clicking noise you get when using the turn signal). When you apply the brake pedal the noise stops unless you have the turn signal on. I've called a couple of different garages and the dealership and they had me try the brakes and blinker together which the tail lights all work fine. With brakes applied blinker work fine. Some times the clicking noise will go away on its own but it's there more than it's not. Any ideas on what this might be?
Old Jul 6, 2011 | 02:42 PM
Unicorn333's Avatar
Unicorn333 is on a distinguished road
I have had the same thing happening on mine for over 250,000 miles and things are running fine. It is annoying
Old Jul 6, 2011 | 07:00 PM
Rapidly activate and deactivate the hazards. See if that changes things. Even if it doesn't, the problem is likely your hazard switch. If the issue hasn't damaged the rest of the multifunction switch, you can replace just the hazard switch for ~$18 or so. The details are covered in the Tech Article (DIY) section. Just click on the index link in my signature below.
Old Jul 10, 2011 | 01:45 PM
arkman8208's Avatar
Thanks I'll give replacing the hazard switch a try.
Old Jul 10, 2011 | 02:34 PM
Magman's Avatar
Magman is on a distinguished road
I own two 98 Blazers and both were doing the same thing. I replaced the multifunction switches on both Blazers two days ago and they're working flawlessly now. Bought the switches off e-bay for $60 a piece (didn't know I could have just replaced the hazard switch), but anyway - took me 3 hours for the first one, 2 hours on the second. So it's not too bad of a job. I lived with one of the Blazers clicking for years, no other known problems other than the annoying noise. Good luck on yours!
Blazinflaboy
Jun 22, 2010 09:03 PM
p72lwor
14
Jan 8, 2010 06:16 PM
dion21379
Jun 20, 2006 05:35 AM
mandi
May 3, 2006 11:02 PM
blazergirl15
Aug 28, 2005 11:17 PM
