Dash ABS & brake lights several questions 2001 Blazer LT 4x4 4.3l
Old Feb 7, 2018 | 06:02 PM
FLHTK's Avatar
FLHTK is on a distinguished road
Default Ok Great!
In about a week the temp should be in the 40's & I will start my assault. I've got a set of 'bed of nails' leads for my Simpson 260 that should do the trick for the prescribed test. I'm hoping it's a bad ground. I just want to confirm before I spend any money replacing the module. I'll post once I check.
Originally Posted by rockp2
Just to clarify, the voltage drop test described doesn't check the EBCM itself (I should've pointed that out). Rather it checks to see if there is high resistance in the ground wire itself between the EBCM and the ground G110. If there is a voltage drop, then there is probably corrosion in the wire and replacing the ground wire could solve the problem. The EBCM is susceptible to high resistance.
Theoretically, if he did have a voltage reading above 100mv (indicating high resistance in the ground wire) he could:
1. Leave the voltmeter installed as described
2. Take a fused jumper wire and attached to the B(-) post
3. Starting at the G110 side of the ground wire, cut/strip the ground wire back a couple inches at a time
4. Connect the fused jumper from B(-) to the ground wire at the cut/strip
5. KOEO, foot on brake, check the volt meter (obviously this will be much easier with a helper)
Once the volt meter drops to 0 volts (+/- 100mv), that's the spot he cop splice in a new wire and run the new wire to G110. Then do the original voltage drop again to confirm he has achieved good ground. Then disconnect the volt meter (not forgetting to remove the T-pin!), and see if he has a fix.
K
ussexplorer
May 24, 2017 06:00 AM
chassy
Jan 11, 2016 07:40 PM
Joey1986Z
37
Feb 10, 2015 12:12 PM
96jimmyslt4x4
Jun 11, 2011 12:01 AM
agentm
Oct 16, 2006 12:56 AM
