Defroster Switch Diagram
Old Jun 27, 2011 | 02:51 PM
ProjectICE's Avatar
ProjectICE is on a distinguished road
Exclamation Defroster Switch Diagram
Ok so i never use my rear defroster.
I want to turn the switch for it into a switch for something else
but i need the wiring diagram for it.
There are 5 wires leading off of the switch and i have no clue what any of them are for.
i have searched EVERYWHERE for this wiring diagram but have come up empty
if you can help me i would greatly appreciate it
1988 Chevy S10 Blazer
4.3L V6
2wd 2dr
**Rear Defroster switch located on left of cluster...right above the light controls**
Old Oct 31, 2011 | 12:39 AM
arthur.stone1's Avatar
arthur.stone1 is on a distinguished road
Default Here you go!
Old Oct 31, 2011 | 02:44 PM
Blazers.B.Kewl's Avatar
Blazers.B.Kewl is an unknown quantity at this point
Wow, I've been looking for this diagram too. Thanks a lot! One question. What are the "Gas Cylinders" that are in-line with the defogger itself?
Old Oct 31, 2011 | 02:45 PM
Thogert's Avatar
I believe those hold up the lift glass or hatch, whichever you have.
Old Oct 31, 2011 | 04:54 PM
xgiovannix12's Avatar
those are the gas loaded shocks that hold up the glass
Old Nov 1, 2011 | 09:18 PM
Ah, that makes sense. I didn't expect for those to be called out specifically in the diagram (figured it would be counted as a wire..). Thanks
Old Aug 4, 2012 | 10:11 AM
JustDestined's Avatar
JustDestined is on a distinguished road
Hi guys, is there any reason that the blazer defroster control switch could not be replaced with a simple toggle and led indicator light to fire the timer relay? I'm putting aftermarket heated mirrors on a 93 fullsize that never had a heated option. Thanks in advance for any answer.
Old Aug 27, 2012 | 09:40 PM
Ramisclend's Avatar
Ramisclend is on a distinguished road
Great. I have been looking for this diagram as well. Does this diagram also applies for the 2001 model with the same engine. My Blazer came without the defogger and I have been trying to figure out the wiring to see what I need do to add one. I got the controller with the defogger from a yunk yard as well as the rear window. The wiring in the back of the controller is identical and it is hard to tell which are the proper wires for the defogger. So it is hard to trace. Would the timmer be part of the controller? this diagram shows it as a separate device. Where would it be located. Thanks in advance for any assistance you could provide
Old Mar 30, 2013 | 04:17 PM
1997GreenBlazer's Avatar
1997GreenBlazer is on a distinguished road
Where is the defrost timer located?
Jonas
Jan 11, 2025 03:07 PM
pfsantos
Nov 22, 2013 01:27 PM
my_83toy
Oct 22, 2012 07:49 AM
drumminsoul
Dec 6, 2011 08:02 PM
86FIFI
Sep 26, 2011 09:12 PM
