dim headlights
Well, depends, do they just stay dim?
or do they fluctuate, get brighter and then dim.
If they just stay dim, your bulbs could just be getting old, Halogens as they get older, they start to dim down, your lenses could also be oxidized
If they fluctuate noticeably, It could be a few things, could be a ground (easiest thing to check) or it could be your alt going bad
I would try a new set of bulbs first, Check out silvania silverstars or Philips XP's, I have philips xp's and they are unbelievably bright
Yup Rich. The Alt PWM mod references the alt to B+ of the bat not the PCM. The headlight relay mod sources headlight current from the bat, not the dash switches. The big3 lowers impedance for all electrical loads. I will also look into Philips XPs Are they a better value than Silverstars?
I have tried both, even side by side, and Philips XP's are brighter, and produce a more white light than silverstars. I have not done the test on a car without a harness though, But I would imagine the same outcome.
Dieseldog95
Nov 10, 2010 07:10 PM
NUM-1-GM-FAN
Apr 22, 2010 08:04 PM
