Door jamb switch
Old Sep 1, 2012 | 04:56 PM
tbirdguy's Avatar
tbirdguy is on a distinguished road
Default Door jamb switch
Can anyone tell me how to remove the door jamb switch on my 2003 Blazer? It looks as if you just pry it out, but when I tried it seemed there is something retaining it.
Old Sep 1, 2012 | 06:50 PM
Rottidog's Avatar
It probably has 'ears' on it that pop out to hold it in place. Maybe try some flat precission screw drivers & a thin blade like a putty knife. Pull it out a bit with the putty knife & use the screw driver/s to push the ears into the switch housing.
Old Sep 2, 2012 | 12:50 PM
tbirdguy's Avatar
Sir,
Thanks, I'll give it a shot!
Old Feb 18, 2013 | 11:58 AM
pduggan's Avatar
pduggan is an unknown quantity at this point
Default Door jamb switch - wire
I'm, trying to replace the driver side door jamb switch. Same 2003 Blazer.
The clowns at the car wash broke it off and just jammed the cable and connector into the dark infinity of the space under the fuse panel.
Any ideas as to how to retrieve the connector and wire?
Thanks in advance.
Old Feb 18, 2013 | 10:53 PM
Bildo V.'s Avatar
Bildo V. is on a distinguished road
theses can be accesed by removing the kick panel from the underside of the dash u can also remove and install them this way as well
Dadatone
Nov 8, 2021 09:34 AM
beardface
Jan 7, 2014 04:16 PM
beardface
Jan 7, 2014 03:34 PM
h2opro
Nov 12, 2010 09:04 AM
tilley101
Jan 26, 2008 10:02 PM
