Dual batteries, under the hood
Old Jan 20, 2019 | 09:39 PM
cleburne red's Avatar
Default Dual batteries, under the hood
So, in preparation for getting a winch, I'm beginning to plan for adding a second battery. I've pretty much got it all hashed out as to how it will be wired, isolators, big 3, all that. What I'm wanting to know is who here has installed one under the hood of a second Gen?
It's not an option to have in the back, I often fold down the seats for cargo room. What I'm thinking is the same spot driver side, as the factory location on the passenger side.
My windshield washer reservoir leaks, and the pumps don't work anyway, so it's already been removed. The air filter I'll probably change to some type of cone/inline, and run it on top of the driver inner fender. My abs pump is long since gone, so there's some room there. I do have an auxiliary fuse box about where it used to be, though.
So, if you got dual batteries, snap a pic, and post it up, to give me ideas!
Old Jan 24, 2019 | 10:54 PM
Is a single larger battery not an option?
Old Jan 25, 2019 | 06:19 AM
If it was just for a winch, maybe. Although I've got the largest physical battery shoved in there that I can, now. I have to unbolt the radiator and slide it over to get it out.
The reason I want a second, is to be able to run lights, inverter, etc during camping trips, with no worries about not being able to crank the truck the next morning
Old Jan 25, 2019 | 06:40 PM
If a second battery is only for peace of mind, then perhaps a lithium ion battery jump pack would solve that. But if your electrical demands are great enough that one battery is sure to never be enough, then I can see how having a second battery is a necessity.
Have you worked out an electrical budget for your truck? I did that for my small sailboat to work out estimates of the size of solar panel I would need to recharge my handheld VHF radio and run my navigation lights. Perhaps that could help confirm your need for a second battery?
BTW, this is the jump pack I got. I've used it a couple times to start my friends' cars. Really easy to use and you can keep it charged by hooking it up to a accessory power outlet in the truck while you are driving although it keeps its charge for many months: https://no.co/gb40​​​​​​​
Old Jan 25, 2019 | 06:46 PM
I mean, you make a lot of good points. But what you're not taking into account is the amount of offroad cool points I would get with a second battery lol!
I plan on adding some more lights, inverter, and a winch, at least. One could probably work, but I would feel better with two. Plus, I think it would be a fun project
Old Jan 26, 2019 | 10:52 AM
go chevy's Avatar
Neat project, keep us posted... I am lazy lol, I would hate too undo my alternator too be able too pull my battery out
Old Jan 26, 2019 | 11:41 AM
Hopefully I can start on it soon. I figure I want a winch as my next "big" purchase, and I want the charging system sorted out before that. I've already obtained some 1/0 welding wire, in black and red. Just need to make it to a junkyard and yank a battery plate, and see what it will take to work on the passenger side
Old Jan 26, 2019 | 12:45 PM
Well, you GOTTA go for the cool points!
On a more serious note, have you considered a second battery that has a smaller form-factor or perhaps two more smaller batteries instead of the second battery being one full-sized (in dimension) battery?
Old Jan 26, 2019 | 01:55 PM
Hadn't thought of that. I want the second one to have at least as much capacity as the main, since I'm going to wire it such that I can self jump-start if the main battery dies.
Old Jan 26, 2019 | 02:03 PM
After reading what your intended uses are, I would suggest that if you are not already familiar with it, you might look up what people do when they wire-up their multiple battery systems on cruising power-boats or sail-boats. They have faced and solved many similar problems.
