ECM fuse
Well, I have a problem with the ECM1 fuse that keeps blowing. If Penelope is just running, everything is good. But I cant drive 3 feet without the fuse blowing. Obviously, there is a short, but I would like to know if its a wire or the ECM. Thanks, fellow wrench turners.
So, I've discovered the fuse doesn't blow if I drive on smooth road, but even the smallest bump or shake...like the bump in front of the driveway or closing the door...the fuse blows. I'm perplexed.
sounds like a shorting wire somewhere
Sounds like a bad ground to me somewhere the ground is getting disconnected and blowing the fuse
do a search, you will find it has happened to others. might get some idewas of where to look.
check crank sensor wiring, common for the pink(power) wire to melt and hit ground. |
Yeah, mine melted on one of the manifolds. Different engine, but still.
Check what thogert said, just happened to me also. Wire melted and touching the passenger side manifold
I found it, it was a melted wire. Thanks for your help guys!!
which wire?
