ECM fuse
Old Sep 29, 2013 | 03:07 PM
brain7734's Avatar
brain7734 is on a distinguished road
Default ECM fuse
Well, I have a problem with the ECM1 fuse that keeps blowing. If Penelope is just running, everything is good. But I cant drive 3 feet without the fuse blowing. Obviously, there is a short, but I would like to know if its a wire or the ECM. Thanks, fellow wrench turners.
Old Sep 29, 2013 | 06:44 PM
brain7734's Avatar
So, I've discovered the fuse doesn't blow if I drive on smooth road, but even the smallest bump or shake...like the bump in front of the driveway or closing the door...the fuse blows. I'm perplexed.
Old Sep 29, 2013 | 06:48 PM
coolasice's Avatar
coolasice will become famous soon enough
sounds like a shorting wire somewhere
Old Sep 29, 2013 | 07:57 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
Sounds like a bad ground to me somewhere the ground is getting disconnected and blowing the fuse
Old Sep 30, 2013 | 05:38 AM
coolasice's Avatar
do a search, you will find it has happened to others. might get some idewas of where to look.
check crank sensor wiring, common for the pink(power) wire to melt and hit ground.
Old Sep 30, 2013 | 09:12 PM
Thogert's Avatar
Yeah, mine melted on one of the manifolds. Different engine, but still.
Old Oct 1, 2013 | 02:48 AM
newguy's Avatar
Check what thogert said, just happened to me also. Wire melted and touching the passenger side manifold
Old Oct 1, 2013 | 07:38 AM
brain7734's Avatar
I found it, it was a melted wire. Thanks for your help guys!!
Old Oct 1, 2013 | 11:14 AM
coolasice's Avatar
which wire?
roddy
Jun 28, 2012 04:52 PM
DREWZBOY
Apr 8, 2010 11:50 PM
brooks66
May 7, 2008 05:40 AM
BigGreenMonster
14
Jan 9, 2007 10:08 AM
Lowtruck94
Jul 17, 2006 01:24 AM
