Electrical issue with Dome, Map, Vanity Lights
Old Apr 11, 2012 | 03:46 PM
Aeratvs's Avatar
Aeratvs is on a distinguished road
Default Electrical issue with Dome, Map, Vanity Lights
Just purchased a 2001 Chevy Blazer 4x4 LT. The interior lights. Dome, map, and vanity lights will not go on. Replaced fuse, no help. Played with Dome Override and it occasional makes a chime noise but no luck getting interior lights working? Temp/Compass works fine as well as the rest of the electrical, (with the exception of the Air Bag light which is on (and occasionally goes off after a hard bump). Previous owner said it was caused by a loose spring???)
I've seen some similar responses here about the lights (even replied to one but no response) also not sure what is what when it comes to parts in the vehicle, so pictures or details would certainly help this noob.
Any assistance would be greatly appreciated.!!
Thanks!
Will Peters
Old Apr 13, 2012 | 01:07 AM
contour1's Avatar
contour1 is on a distinguished road
blown bulbs?? it is 11 1/2 yrs old..
Old Apr 13, 2012 | 10:21 AM
Aeratvs's Avatar
I suppose anything is possible. I guess I never considered it since it involved so many bulbs (10). I'll get a tester and check. Anyone know how to access the map bulbs? Do they unscrew or??
Thanks!
Will
Old Apr 13, 2012 | 11:46 AM
pettyfog's Avatar
Here's the bulk of the control circuitry
Attached Thumbnails Electrical issue with Dome, Map, Vanity Lights-ckt_ltg_bcm_r.jpg
Old Apr 14, 2012 | 12:59 PM
Aeratvs's Avatar
Many Thanks!!
Not sure what to do with it, but realize that is my ignorance. At least I have a better idea of what is involved and man, is it involved. LOL
Thanks Again!
Will
Old Apr 15, 2012 | 07:38 AM
Welder George's Avatar
Welder George is on a distinguished road
Hi, I've also just bought a blazer with similar dash light problems. So I looked on this site for a fix but what I found were loads of people with the same problem. Having fixed mine I thought I'd share. For anyone interested my blazer had fairly recently (and at least two owners) had an aftermarket stereo fitted.
This was the cause of the dash lights not working.
I'll now list the information I was looking for.
The wire colours behind the stereo (from the vehicle) are as follows:
pink - power aerial
black - earth
orange - permanent live
green - switched live from ignition
purple/white trace - switched live from light switch
grey - connect this wire to the purple/white trace to make the lights work again.
That's this years good deed done and it's only April!
97blazer8488
Nov 4, 2015 04:48 AM
96chevblazer
Oct 30, 2012 04:45 PM
kmartin
Jul 26, 2011 04:05 PM
crazyjust
Apr 5, 2010 10:35 PM
68Datsun510
Sep 15, 2009 06:10 PM
