Electrical issues with 1998 Blazer
Old Sep 15, 2017 | 12:29 PM
Lesley Sanders Boyer's Avatar
Lesley Sanders Boyer is on a distinguished road
Default Electrical issues with 1998 Blazer
Everything on the dash, including all the warning lights, come on and won't turn off. When you turn off the vehicle, all those lights stay on. Sometimes you can turn the truck on and off again a couple of times and they will turn off, but something is staying on because it is draining the battery. I know nothing about electrical issues and have no clue where to start. Ideas?
Old Sep 15, 2017 | 12:45 PM
sounds like the ignition switch lock cylinder in the column
Old Sep 15, 2017 | 02:36 PM
Rusty Nuts's Avatar
Welcome to the forum. You tube parasitic drain test to learn the procedure and perform it on both fuse panels to find which circuit is draining the battery. Solving that issue first may correct the cluster problem.
sportjunkee
Jul 17, 2015 01:39 PM
JoSHN
Sep 14, 2012 04:56 PM
didgeridood
Dec 27, 2010 08:50 PM
KIllarb634
Dec 20, 2007 10:31 PM
mrartie
13
Jan 2, 2007 09:28 PM
