Error on milage display
Old May 18, 2024 | 08:59 AM
Jackal713's Avatar
Jackal713 is on a distinguished road
Default Error on milage display
Hey everyone, long time reader first time poster. I have a 89 s15 jimmy 4.3l. Everything on the dash is working as it should except for the milage, It only displays "error". Unfortunately I am not with in walking distance to the truck, it's about an hour north of where I live. Just looking for ideas. Hope somebody on here can point me in the right direction. Thank you!
Old May 21, 2024 | 09:08 PM
GeorgeLG's Avatar
The IPC is tough for the shade tree mechanic because most of the information is communicated on the single wire Class 2 serial data bus. Its a stream of ones and zeros with every module talking on the line simultaneously. About all you can do is look at the data line if you have a scope and make sure the data stream looks OK. If that bus were being corrupted by say a bad module then other things would be wrong. If your scanner can read live data without issue then this is not likely happening. That leaves you with either a rebuild if available for these trucks or a trynostic IPC swap.
George
filthyjimmy89
The Chop Shop
May 13, 2015 11:19 PM
Muscrat
Jun 13, 2014 06:55 PM
Smitty Smithsonite
Oct 6, 2010 04:29 PM
kelli5387
Feb 17, 2009 11:50 PM
DM6156
Sep 22, 2007 08:52 PM
