Female in the Forum bbbut dont be scared
Old May 9, 2012 | 12:23 AM
linsgm's Avatar
linsgm is on a distinguished road
Default Female in the Forum bbbut dont be scared
will a 1000 watt amp cause a melt down in your system IF NOT properly wired up? OH, i have 92 blazer 4.3 vortec I can answer this question myself YES! SSoooo what is making all my wiring get so hot LIKE the wire coming off the ALTERNATOR but i have already replaced alter WITH NEW ONE NOT REFURBISHED!! and my battery guage keeps dropping way down , also replaced NEW BATTERY, AAND STILL my trucks dead again after sitting for just 2 weeks AND DONT TELL ME THATS NORMAL! PLEASE HELP
Old May 9, 2012 | 12:58 AM
Thogert's Avatar
I would do 'the big 3' wiring upgrade. And if that doesn't stop it from dying, you might need a larger alt/ bigger or extra battery.
Old May 9, 2012 | 04:44 AM
linsgm's Avatar
would u explain the big 3 to me?
Old May 9, 2012 | 07:22 AM
chris015's Avatar
ok ok here we go...
What size wire are you using for the power wire to the amp? It'll say it on the wire "4 gauge,8 gauge etc" If you say you are using a power cord you will be condemned lol.
BIG 3 :
The wire to the alternator,the ground from the battery and the ground wire that runs from the battery to the engine is changed from the tiny wire the manufacturers use to 4 gauge or bigger to help current flow etc. Does it help? YES.
for 1000 watts (please state what amp you have and model) you need 4 gauge power wire from the amp,to the battery. With a fuse 16 inches from the battery closer to the battery.
Old May 9, 2012 | 07:30 AM
neo71665's Avatar
Sounds like undersized wiring
Old May 9, 2012 | 09:24 AM
wyzardd's Avatar
wyzardd is on a distinguished road
So, correct me if I'm wrong, but did two guys just tell a lady that size really DOES matter?
Traitors.
Old May 9, 2012 | 09:36 AM
Rottidog's Avatar
Traitors.
LMAO bunch of suck-ups!!! TFF
Telling her what she already knows: She needs a bigger wire!
Old May 9, 2012 | 09:38 AM
chris015's Avatar
Thankfully there is a few of us that dont have to worry about that issue.
Like a boss.
Old May 9, 2012 | 09:42 AM
Rottidog's Avatar
Like a boss.
Ohhh you're single, I see.
On topic... there still is the issue of her truck bleeding the battery after sitting 2 weeks, something is grounding out or 'always on' for a static current to something I think.
Old May 9, 2012 | 09:49 AM
pettyfog's Avatar
Which USED to happen a lot back in the nineties when I was helping my kid and his friends sort out probs with sound system Amps.
