First gen reverse lights - not always working
Old Sep 25, 2013 | 12:56 AM
richphotos's Avatar
Default First gen reverse lights - not always working
This has been a problem since I got the truck, was also a "problem" in my previous 94, and I was never able to figure it out, and really, put it on the back burner since its not a huge problem...
but now that I have new LED reverse lights that are real bright, I would like them to work.
So what could cause this problem?
I have tried wigging the lever up and down (column shift) and that did not work, what I did find to work, was when I move the lever front to back, is when it will start to work (the shift lever that is)
I just had the column apart, I could do it again if absolutely needed, but I dont want to LOL
With that being said, where would the "reverse light switch" be located on a first gen?
Old Sep 25, 2013 | 06:41 PM
abig84's Avatar
im so out of practice on these older s10s. i dont think they have the range sensor on the transmission, should still be on the column above the brake pedal. a lot of my older trucks they never seem to line up right, like if i go from park to reverse they dont come on i have to move the shifter up towards park a bit to get them to come on.
its probably that sensor on top of the column, ive seen them as ive replaced many columns but never had one go completely bad where i had to change it
Old Sep 25, 2013 | 07:15 PM
richphotos's Avatar
wiggling the shifter up and down does not get them to come on, when I pull the shift lever towards me is when they come on. Which makes me think its the reverse light switch...
The reverse light switch is located in the column? where abouts, there is no photo of this in my repair manual.
( I have the 4l60e tranny btw)
Old Sep 25, 2013 | 07:20 PM
chris015's Avatar
Richard,
its down on the bottom of the column. on top. white slight u shaped sensor. as you move the shift lever etc it moves a flat shaft (hidden in the column,dont look for it) which moves that sensor. if the sensors broke,lights go poo.
If i remember correctly you just unplug the sensor,and there is a tab on each end that you press towards the center and it'll pop off.
(read your pms. douche lol)
Old Sep 25, 2013 | 08:56 PM
richphotos's Avatar
Originally Posted by chris015
Richard,
I have no PM's you feminine hygiene product LOL
The bottom of the column on top? whaaa? that is like saying "its to the left of the right
and looking at the reverse light switch on napas site... it threads into something, so there is no popping off of anything but the connector... ? unless I am looking at something completely different.
backup lamp switch
Attached Thumbnails First gen reverse lights - not always working-si_ls205_front.jpg
Old Sep 25, 2013 | 09:01 PM
rexmburns's Avatar
Super Moderator
Now now children!! Sorry rich I got no help for ya on this one in just along for the ride lol!
Old Sep 25, 2013 | 09:09 PM
richphotos's Avatar
Its more of an annoyance than a problem, since I now have these super bright LED reverse lights, would be nice if they always came on LOL
Old Sep 25, 2013 | 09:15 PM
chris015's Avatar
1983-1994 Chevy Blazer S10 5 Terminal Neutral Safety Switch at 1AAuto.com
this guy. drop the column ( 2 bolts) you'll see it at the bottom. 90% sure
edit: REsent you the pm i sent u yesterday.
Old Sep 25, 2013 | 09:18 PM
richphotos's Avatar
oh the neutral safety switch!! gotcha!
Old Sep 25, 2013 | 09:19 PM
chris015's Avatar
it does the reverse lights too.
(i scrapped one months ago with the old column.)
i need to start saving crap.
