Flash-To-Pass Not Working
1 Attachment(s)
Heyyyy, I've got a 98 ZR2 Blazer, and my flash-to-pass high beams are not working. Also, I believe my high beams also won't work at all if the low beams are not already on, even if you click. So at night, flash-to-pass still doesn't work, but clicking the high beams does. During the day, no high beams at all.
I was told there is a relay for this feature that probably just needs to be replaced. I looked in the fuse panels and I'm not seeing anything with an obvious label for this. Here's a pic of my under-hood fuse panel key. Any suggestions? https://blazerforum.com/forum/attach...ine=1448476903 |
There is another block of relays under the dash. There are good posts and pictures of the "body relay block" in this forum.
I do not think that FTP was added until 1999.
I'm pretty sure this truck had it when I got it. If not, I'm quite sure I was at least able to flash my high beams during the day when the lights were off.
