Fog Lamps
Old Mar 21, 2016 | 01:47 PM
chazman's Avatar
chazman is on a distinguished road
Question Fog Lamps
I am looking to put a light bar on my Blazer and taking off the brush guard. I have the fog light relay already installed on the car from the factory. I am looking to see if anyone has a picture of where the stock from bumper harness looks like on the ones that have fog lights stock. Wiring diagrams and google are not getting me anywhere. I am stumped.....
Old Mar 22, 2016 | 04:50 AM
Thogert's Avatar
If you are trying to use the stock fog light switch and relay on a truck that didn't come with that option from the factory, it won't work unless you reflash the BCM.
Old Dec 27, 2017 | 05:18 PM
Strangerock's Avatar
Strangerock is on a distinguished road
would it be possible to wire the factory fog light switch to a relay and then the aftermarket lights without programming the bcm? . I have the switch from a doner and my truck did not come factory with fogs....I currently have just a toggle that works but the factory switch would be cool.
Old Dec 28, 2017 | 05:49 AM
Snap-Off's Avatar
Snap-Off is on a distinguished road
Well, here's a diagram of someone using a PAC module to do it:
https://blazerforum.com/forum/lighti...-sticky-85674/
Not a whole lot of documentation though. Kind of leaves you hanging wondering what the end result was. For all I know , it either worked well , or caught his truck on fire.
Old Dec 28, 2017 | 11:46 AM
well I guess I will gather up a relay and maybe my buddy still has his VIN from his 2000 blazer with factory fogs ....I do have a Tech II so programing shouldn't be to tough....feature 3 with the PAC7 would be sweet though.
Old Jun 5, 2018 | 08:44 PM
kiddbrother57's Avatar
kiddbrother57 is on a distinguished road
Thumbs up Bypass bcm for factory fog lights
HOW TO BYPASSING BCM ON 2001 CHEVY S10
FOR FACTORY FOG LIGHTS & IT'S EZ!
CONNECT TO MOMENTARY PUSH BUTTON N/C
TO (BLUE WIRE) PIN #30 & THE OTHER SIDE OF
SWITCH TO GROUND(THE SWITCH USED TO TURN OFF LIGHTS)
CONNECT TO (WHITE WIRE) PIN #85 12VOLT +
THRU A FUSE & SWITCH 12V THRU IGNITION
SO THE FOG LIGHTS TURN OFF
CONNECT TO PIN #86 (BLACK WIRE) TO PIN #87
(YELLOW WIRE) TOGETHER
& TO THE ORANGE WIRE
ON BACK OF FOG LIGHT SWITCH & CUT &
ORANGE WIRE TAPE END OF WIRE IN TO
HARNESS & RUN A WIRE TO DARK GREEN/
WHITE WIRE & CUT & TAPE DARK GREEN/
WHITE WIRE into HARNESS
THE RELAY IS A STANDARD FOG LIGHT RELAY
THIS IS A LATCHING RELAY SETUP GM WANTS
$300 TO UPDATE THE BCM! I DON'T THINK SO!!!
KIDD
jayj99jimmy
Dec 22, 2011 02:28 PM
bionichicken
Dec 22, 2010 11:57 AM
brad_blazer
Oct 28, 2010 11:13 PM
Dogger
Nov 15, 2009 08:13 PM
ebornand
Jun 9, 2009 08:50 PM
