front turn signal led problems
Hey everyone im having an issue with my truck its a 99 blazer. I recently put led bulbs in the rear lights but when I put the bulbs in the front turn signals at the indicator shows it constantly on but no flashing but when I put the stock bulbs back in it flashes fine the only thing I have done is mod the flasher relay to stop the hyperflashing. Has anyone had this issue before?
Thanks for looking and Merry Christmas!! |
I just went through the same scenario in my 04. In the end, the issues with just throwing LED's in these trucks is because of the way the marker light in the headlight uses the turn signal bulb below it for ground. And the only way it's like that is so the two lights alternate when the turn signal flashes...
Like you, I put LED's all throughout the truck, in the tail lights, front turn signals, and marker lights. Mad to do the flasher mod after just installing the rear LED's, but that wasn't enough for when I put the fronts in. I had to put a load resistor across the ground and turn signal 12+ on the turn signal socket on both sides up front, and that solved the dimly lit inside indicator lights. In my case I also had to solder on a diode as one of the legs for my front LED's because I was getting feedback and the running lights wouldn't work... may not be the case in yours though, depends on the bulb |
thanks for the reply man.it looks like im gonna be putting resistors in, I even tried the led flasher relay part ep-29. fixed the speed but still indicators are lit inside, ill post back with the results.
You will just need diodes to prevent back feed into the circuit. the load resistors are just to prevent the hyper flash.
(Post 640723)
(Post 640752)
without the load resistors, my signals wouldn't flash at all (with LED's in the front and rear), and that's after the flasher mod
If you got an electronic flasher, there should have been no need for load resistors and only diodes to prevent back feed into the system. :icon_saywhat: |
I just moded the OEM flasher by popping it open and lifting a leg on the IC on the circuit board inside. Free fix for me, since I already had a handful of the load resistors sitting around lol
i have leds on whole thing front marker, front turn signal, taillight, back up light, and leds in the cluster plus change relay i dont have any problems with it.
(Post 640252)
