fuel gauge always reading way past full
Old May 1, 2013 | 12:46 AM
morganpainter's Avatar
morganpainter is on a distinguished road
Default fuel gauge always reading way past full
i have an 89 chevy blazer k5 tbi the fuel gauge stays way past full. i took the dash off to see if it was just stuck, i moved it to half way and when i started it up it went right back to past full, ive heard it could be a bad ground wire or bad sending unit, or bad gauge cluster. any help before i start taking the tank and pump out.??
Old May 1, 2013 | 07:07 AM
chris015's Avatar
bad ground came to mind. check the ground from the sending unit to the frame.
Old May 1, 2013 | 12:25 PM
i have dropped the tank to check the pump and undid the ground but it was doing the same thing before and after i dropped it. unless its in the wire itself or bad connection on the sending unit side
Buttrock21
14
Jan 4, 2015 02:00 AM
Jerry.rm125
Sep 4, 2014 02:45 PM
Gmas95
Apr 22, 2014 04:58 PM
scphill34
May 8, 2013 09:27 PM
Olds Guy
Nov 11, 2010 09:21 PM
