G.e.m. what does it do?
Old Feb 24, 2024 | 04:36 PM
HopeFiend's Avatar
HopeFiend is on a distinguished road
Default G.e.m. what does it do?
I have a few issues and wonder how many tie back to the g.e.m.
*battery light stays on but although charges fine and battery is good
*fuel Guage doesn't work and low fuel light stays on
*Rear wiper don't work
*rear hatch button on dash dont work (button on tailgate does)
*Front wipers sometimes work sometimes don't
*The alarm works But the truck won't go onto program mode for the fob (keyless entry module was changed out and tried in another vehicle and is good)
*Abs and red brake light on dash on and off together sporadically
*Radio and windows turn off with the ignition switch without the normal delay or when open door
*don't have to press brake to shift
Stuff like that...
Could a faulty g.e.m. be the culprit?
Old Feb 24, 2024 | 07:49 PM
GeorgeLG's Avatar
What is a g.e.m.?
George
Old Feb 24, 2024 | 09:24 PM
AJBert's Avatar
My wife is a gem. I, too, don't have a clue what a g.e.m. is either, let alone how it relates to Blazers and Blazer type vehicles.
Old Feb 27, 2024 | 04:05 PM
GeorgeLG's Avatar
You better not tell your wife that you don't know what she does. LOL.
George
Old Feb 28, 2024 | 01:01 AM
HopeFiend's Avatar
Generic electronic module or body control module or whatever...
Old Feb 28, 2024 | 01:52 PM
Stuff like that...
Ah, the BCM (body control module). Yes, at least in the GM service manuals many of us have, they are called BCMs. And yes, the BCM is connected or runs many of the items on your list. Instead of the BCM being bad, perhaps there is a fault in the wiring harness or you have some bad/corroded connections?
If you supply the year of the Blazer and other info, many of us can scrounge up the info from our service manuals.
Old Feb 28, 2024 | 03:57 PM
GeorgeLG's Avatar
BCM, got it. As Christine said get us a year and we can help you work through the list.
George
Old Mar 2, 2024 | 10:46 AM
HopeFiend's Avatar
2000 Blazer, ZR2 , 4x4, Automatic
thank you so much
Old Mar 2, 2024 | 11:46 AM
GeorgeLG's Avatar
This quite a list. I can help you with the whole thing depending on how deep you want to get into it.
The BCM is involved in parts of this list:
  1. Rear hatch button
  2. Key FOB
  3. Delayed power
The VCM (engine computer) is involved in:
  1. Battery light
  2. Fuel gauge
The class 2 serial data bus is involved in:
  1. Battery light
  2. Fuel gauge
  3. Brake lights
The fuel gauge can also be the fuel pump/sender in the tank
The rear wiper can also be:
  1. Dash switch
  2. Rear gate cutout switch
  3. Motor
The rear hatch can also be the dash button
The front wipers can be the MF switch or motor
The ABS light can also be ABS system problems
The delayed power issue can also be the relays
The brake shifter issue can be:
  1. Shifter solenoid
  2. Brake switch
Every problem can be:
  1. Fuses
  2. Power
  3. Grounds
  4. Wiring
If you swap out the BCM as a trynostics experiment the truck will not run and you will need to reprogram the passlock system
The first thing I would do is:
  1. Check every fuse in the UHFB and the accessory panel in the side of the dash
  2. Check the grounds on the engine block
  3. Hook up a scanner to the DLC port and monitor live data to see if you get any dropouts as a first order check of the class 2 data bus integrity
After that if you give a prioritized list we can work our way through your issues.
George
Old Mar 2, 2024 | 12:05 PM
GeorgeLG's Avatar
In answer to your original question as to what the BCM does, it is a computer module under the dash that is involved in:
  1. Door locks
  2. Lighting
  3. Horn
  4. Anti theft
  5. Keyless entry
  6. Warning systems
  7. Transmission
  8. IPC
George
