gauge cluster question
Old Jul 22, 2012 | 07:57 PM
cucv30's Avatar
cucv30 is on a distinguished road
Default gauge cluster question
I have a 99 blazer 4 door i'm fixing up and it had an issue with the airbag sensor which i have now replaced and is working. But i am wondering, i picked up a good cluster at the local yard out of a 2000, but when installed the airbag light will not go off. So does anyone know the difference between the 2 years? The light will go off with the original cluster.
Old Jul 22, 2012 | 09:10 PM
jaked up's Avatar
jaked up is on a distinguished road
there are 2 airbag sensors maybe you need to replace the other one? posably
Old Jul 22, 2012 | 09:28 PM
Rather than guess at the problem, get the airbag system scanned by a compatible scan tool and report the code back here.
Clusters sometimes need some programming to become friends with the BCM & PCM, especially if there are differences in the clusters.
Old Jul 24, 2012 | 05:44 PM
cucv30's Avatar
I'm not guessing, i have an OTC Genesis scanner and it says everything is ok. So something must be different in the 2 years of clusters.
blazerguy09
Jan 7, 2015 03:26 PM
aksallday
Dec 3, 2013 03:52 PM
Drew14221
Jun 19, 2010 04:48 PM
3kidblazer
Feb 1, 2009 11:22 PM
WLB
Mar 3, 2008 10:08 AM
