gauge cluster wont work
Old Oct 6, 2010 | 10:20 PM
slammed95blazer's Avatar
slammed95blazer is on a distinguished road
Default gauge cluster wont work
Not sure if this is the right place to post this but im gonna give it a try. today while driving my gauge cluster completely stopped working. none of the guages work at all. when i have the switch up for the interior lights my door chime comes on.. the truck is a 95. if anyone knows what the problem may be id love for some info.
thanks.
Old Oct 7, 2010 | 12:05 AM
MTopper's Avatar
check fuses. sound systems can blow fuses that have nothing to do with radios.
if that doesn't do anything let us know and i can rack my brain some
Old Oct 7, 2010 | 06:55 AM
Could be the early signs of an ignition switch failure.
Old Oct 7, 2010 | 12:55 PM
mtopper, thanks. I honestly didnt even think about that. and yup, sure enough it was the fuse.
Old Oct 7, 2010 | 03:31 PM
so after finding it it was the fuse i changed it. now all they do is blow within 15 minutes of being replaced. i even put a 30 amp fuse there and that blew. im guessing theres a ground issue somewhere??
Old Oct 7, 2010 | 11:54 PM
MTopper's Avatar
did you tap into anything while installing your system?
Old Oct 8, 2010 | 12:01 AM
zerepdivad's Avatar
zerepdivad is on a distinguished road
do yourself and your truck a favor and don't put bigger fuses in when you're popping the correct sizes.
Old Oct 8, 2010 | 01:49 AM
trust me i know this. this was just to see how much gas i had to see how far i could get. it wasnt in there any longer then 5 minutes really.
Old Oct 8, 2010 | 01:51 AM
nope, never. but now the truck is completely dead. while driving home today somethin happened to where the radio and amp had no power. it wouldnt shift at all. i couldnt get the rpms passed 2grand. if i did it would bawg out. that all happened till it finally died 10 minutes away from home. i had it jump started, got right in front of my driveway and it died again. it seemed as if i was runnin off of battery power only. so tomorrow is going to consist of an alt test and any other testing for the elec i can think.
Old Oct 8, 2010 | 11:04 PM
MTopper's Avatar
you could have easily fried your alternator. i did that to my old sunbird. it was a pain. upgrade instead of replace
