Gauge Lights Stopped Working
Old Sep 11, 2011 | 08:58 PM
DoubleSh0t's Avatar
DoubleSh0t is on a distinguished road
Default Gauge Lights Stopped Working
I pulled my gauge cluster today to install LEDs. Most didn't light up, so I pulled them out and flipped them around. Nothing. Tested the bulbs with a spare socket I had and hooked up to a 12v source, they're all fine. I got tired of messing with it and put the regular incandescent bulbs back. Only one of the lights come on.
All the dummy lights work, the gauges work fine, HVAC and door controls light up but the only gauge bulb that lights is the one for the speedometer. Pulled the dash light fuse, it's fine. Does anyone have any ideas what could be causing the issue? The incandescents came out -very- hard and I'm worried that I damaged the sockets.
Old Sep 11, 2011 | 09:08 PM
xgiovannix12's Avatar
Originally Posted by tibby
Just a word of advice, never use the original sockets in the cluster for your led's. There is no physical way to get the original bulb out unless you bend the connector/tab.
Just goto autozone, advance, o'reilly's and get 1/2 inch sockets for each bulb. Yes they are $2.49 or around there, but they will save you in the long run.
I agree to what tibbys trying to say
Old Sep 11, 2011 | 09:22 PM
DoubleSh0t's Avatar
Ah, I didn't see that in the other thread. I'll try that, thanks. Who's brilliant idea was it to make it necessary to replace the bulb and socket? I don't replace my headlight socket every time I blow a bulb.
Old Sep 12, 2011 | 12:14 AM
tibby's Avatar
Default .
Believe it or not this is just a GM issue(whats new right? lol). Ford's gauge cluster sockets were plug n play in the sense that you could pull the bulb out and replace the bulb without another socket.
GM likes to make things difficult and decided they would spot wield the bulb and socket. It is lightly spot wielded and by trying to get the connector/tab out, there is no easy way not to bend it. So your options if the original socket is broken is either goto the salvage yard and get some sockets off a ford, or go buy new 1/2 inch sockets. I just bit the bullet and bought new sockets knowing they would definitely work.
Old Sep 12, 2011 | 08:02 AM
DoubleSh0t's Avatar
I ordered a set of new sockets from someone on eBay. Hopefully they will be here this week. I couldn't see spending the $2.99 each they wanted locally.
Old Sep 27, 2011 | 07:40 PM
DoubleSh0t's Avatar
End result:
Pretty happy with how it looks. Very very bright. The blue kind of washes out the orange needles, and kind of makes them a pale orange/whitish color. Neat.
Old Sep 27, 2011 | 08:18 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Verrrry nice. Looks sweet!
Old Sep 27, 2011 | 08:26 PM
I like !
Old Feb 15, 2012 | 11:18 PM
Nickey619's Avatar
Nickey619 is on a distinguished road
slowsinglecam
Jun 26, 2012 08:42 PM
jstutzman
Dec 19, 2009 03:27 PM
mac6135
Dec 8, 2007 09:18 AM
Stablock
Apr 20, 2007 04:29 AM
